Avnet Boards General Lost micro SD
  • Subscribers 373 subscribers
  • Views 587 views
Lost micro SD
victorreyna
victorreyna over 8 years ago
I'm at work and they gave me a Zedboard to do some work. I've never used one of this before and my computer doesn't detect the board. They gave me the board without the micro SD, and i was wondering if that could be the problem? I followed all the steps and install all the drivers and doesn't work.
  • jafoste4
    0 jafoste4 over 8 years ago
    Are you sure you are using a Zedboard? The Zedboard utilizes a standard SD card not a Micro SD Card. However that is not required to utlize the Zedboard.
    What drivers did you install? DId you install the Cypress USB Uart driver?
    Are you sure your using the correct MicroUSB connector?
    Please go through the Zedboard getting started guide located here http://zedboard.org/support/documentation/1521
    --Josh
  • victorreyna
    0 victorreyna over 8 years ago in reply to jafoste4
    Sorry, you are right, it's SD card. and yeah i follow all the steps and install Cypress even twice cause i read it in one of the guides i download. It's the right connector in the right slot.
  • jafoste4
    Victor,
    Dooes the board power up properly? What Leds are enumerated when your power on the board?
    --Josh
  • victorreyna
    just power (LD13)
