Avnet Boards General SD Card
  • Subscribers 373 subscribers
  • Views 543 views
  • iiot
  • microzed
  • industrial_iot
  • microzed_iiot
SD Card
joaomota1994
joaomota1994 over 8 years ago
I messed up the micro SD boot information, can someone give me the original image that came with it?
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Joamota,
    You can find the factor image under the Getting Started Guides section under the MicroZed Documentation page.
    http://zedboard.org/support/documentation/1519
    --Josh
  • joaomota1994
    0 joaomota1994 over 8 years ago in reply to jafoste4
    I did that! and it worked!
    The board now boots as expected but since i formatted the card i can't find the executable referred in the quick start guide.
    I found online the files in github and created a folder inside the SD card but i can't find them when searching using the board.
    For an instance everytime i plug the SD card in my computer i get 3 different partitions in there: F,G;H (Is it normal?) so i pasted the folder with the files needed for the quickStart in one that says OVERCBOOT(F:) and also in one of the other partitions(i had to format it in order to access it).
    Still can't find it.
    Please help i need this fully functional ASAP!
    Thanks in advance!
    Best regards,
    João Mota
