Avnet Boards General Access the USB in Microzed Board
  • Subscribers 373 subscribers
  • Views 865 views
  • iiot
  • microzed
  • industrial_iot
  • microzed_iiot
gauravagarwal.27394@gmail.com
gauravagarwal.27394@gmail.com over 9 years ago
I'm using Microzed evaluation kit for my development of interface card. Burnt Pulsar Linux OS given as per instruction.
Problem: I'm not able to get the device address of USB (which is just below the Ethernet) .
Doing ls /dev/ttyUSB* or ACM* is not helping me much.
do I have to install any thing?
  • jafoste4
    0 jafoste4 over 9 years ago
    Here are a few posts for you to look at :
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Cannot-get-USB-to-work-on-microzed-7010-with-arch-linux-using/td-p/652816
    http://picozed.org/content/microzed-usb-host-0
    http://zedboard.org/content/microzed-petalinux-20154-kernel-usb-driver-settings
    http://zedboard.org/content/microzed-usb-device-driver-bulk-transfer
    http://zedboard.org/content/microzed-usb-host
    http://microzed.org/content/usb-phy-issue
    --Josh
  • gauravagarwal.27394@gmail.com
    0 gauravagarwal.27394@gmail.com over 9 years ago in reply to jafoste4
    i'm using MICROZED ZYNQ XC7Z020 ,
    So whenever i connect a USB to the USB (Pictorially Just below Ethernet)
    I'm not able to get the device address :
    > usb-devices :
    T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
    D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
    P:  Vendor=1d6b ProdID=0002 Rev=04.01
    S:  Manufacturer=Linux 4.1.33-pulsar-standard ehci_hcd
    S:  Product=EHCI Host Controller
    S:  SerialNumber=ci_hdrc.0
    C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
    I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
    T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=12  MxCh= 0
    D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
    P:  Vendor=0403 ProdID=6001 Rev=06.00
    S:  Manufacturer=FTDI
    S:  Product=FT232R USB UART
    S:  SerialNumber=AI031ZRR
    C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=90mA
    I:  If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
    T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
    S:  SerialNumber=ci_hdrc.1
    : dmesg | grep usb gives:
      [    2.012153] usbcore: registered new interface driver usbfs
      [    2.012246] usbcore: registered new interface driver hub
      [    2.012382] usbcore: registered new device driver usb
      [    2.782025] usbcore: registered new interface driver usb-storage
      [    2.981240] usbcore: registered new interface driver usbhid
      [    2.985457] usbhid: USB HID core driver
      [    3.144868] usb 1-1: new full-speed USB device number 2 using ci_hdrc
      The device is powering but i'm not able to get the device address which actually be something like /dev/ttyUSB*
    Still not able to access the USB plugged in? Any further helps?
