Avnet Boards General MicroZed programming with SIMULINK
  • Subscribers 373 subscribers
  • Views 502 views
anirudh_ab
anirudh_ab over 9 years ago
I am trying to target the microzed 7020 board using SIMULINK HDL coder. I am able to program the board. But when I execute the software interface model I get the following error in the console:
Error while opening: dev/mwipcore
DEV_OPEN_FAILURE: No such file or directory
Can someone suggest what more needs to be done in order to connect the simulink interface model to microzed board. I have downloaded the linux OS for MicroZed Z7020 board.
Should I use a specific linux version to run the interface model? I am currently using
http://zedboard.org/content/ise-145-version-7020
Best Regards,
Anirudh
  • mbrown
    0 mbrown over 9 years ago
    If you're trying to use the MathWorks Zynq HW/SW co-design work flow, you'll need their Linux distribution (and SD image for boot).
    This post may be helpful -- http://www.mathworks.com/help/hdlcoder/examples/getting-started-with-hardware-software-codesign-workflow-for-xilinx-zynq-platform.html
    /Matt
