Avnet Boards General Stock release image not working
  • Subscribers 374 subscribers
  • Views 283 views
I have been creating my Linux environment over the past day or two and successfully building uboot, ramdisk, linux, fsbl, and dtb. One thing I have noticed is that when I build uboot with the instructions on the wiki, it creates uboot.bin and not an elf file, but I am not really at that point yet.
I have a microzed board that I can boot and use in tera term with whatever is loaded from Avnet when the board ships. When I change the boot from qspi jumpers to load from the SD card, I cannot get it to boot. I figured I'd test to see if my files that I generated were the issue. I downloaded the SD card archived image from the wiki and also this website and basically followed the instructions from the wiki and copied them directly to a freshly formatted FAT32 single partition card. I set the baud in the terminal to 115200 and all I am seeing is a single character popping up on the screen every second or two. It doesnt appear to be booting.
Can anyone give me a hint of what is happening or where I am stalling? I guess I wanted to verify that I can load a stock set of files from the wiki onto an SD card and boot before I move to my own files (which also failed to boot) and this seems like the easiest piece of the whole process, but I cant get it working.
Thanks a bunch.
-Joe
    Not sure which wiki you are talking about but there is an archive of the microSD image for the 7010 MicroZed Linux bootable image that can be downloaded from this page: http://zedboard.org/support/documentation/1519 that should work if you have a 7010 MicroZed.
    -Gary
  • zedhed
    0 zedhed over 11 years ago
    Hi Joe,
    In addition to what Gary suggested above there is a Getting Started Guide for MicroZed which should offer some guidance for connecting up the board and running through the basics.  You can download the Getting Started Guide from the Documentation page for MicroZed:
    -Kevin
