Avnet Boards General Loading a FPGA image using u-boot
  • Subscribers 373 subscribers
  • Views 565 views
Is there any training material which shows how to load a FPGA device image through uboot. I have a MicroZed board and would like to use uboot to load the FPGA image and the Linux Kernel iteratively.
Is there any documentation/tutorial information which shows how to use the uboot "fpga loadb" commands?
  • zedhed
    0 zedhed over 10 years ago
    Hi dguthrie71,
    There is no training on this that I am aware of but I think the matter may be a lot simpler than you think.
    If you are looking to load whole bistreams into the PL, then that is pretty straightforward as seen here on the Xilinx Wiki:
    http://www.wiki.xilinx.com/Programming+the+Programmable+Logic
    If you want to be able to load partial bistreams into the PL, then that makes things more complicated:
    http://www.wiki.xilinx.com/XAPP1231+-+Partial+Reconfiguration+of+a+Hardware+Accelerator+with+Vivado+Design+Suite
    -Kevin
