Avnet Boards General UltraZed-EG out-of-the-box Ethernet
  • Subscribers 373 subscribers
  • Views 539 views
tayloral
tayloral over 9 years ago
I'm testing out some things on a new board, but am having an issue with Ethernet.
On both the original SD image and one I made, the Ethernet adapter reports not ready and fails to find a configuration from " Sending discover..." (DHCP server is preset on LAN).  From the video about the starter kit, it seems that it should.
Before I go to far into trying to fix this, am I correct in thinking this should work?
    0 e14 Contributor over 9 years ago
    Make sure you are connected to a GigE port. Please see the Xilinx answer record at https://www.xilinx.com/support/answers/66553.html.
  • tayloral
    0 tayloral over 9 years ago in reply to e14 Contributor
    Perfect, that was it.  Thanks.
    Do you know if there are plans to provide a pre-built image with  > 2016.2 (assuming dynamic switching was added)?  Our LAN is 100M and direct connection is sort of impractical.
    Good to hear it worked for you.
    We most likely won't be updating the Out-of-Box design to the later version of Vivado (then again, we might), however, look for future reference designs posted on our web site for Vivado 2017.x which will support other Etherent rates. These reference designs are usually posted with a pre-build image as well.
