Avnet Boards General unable to restore minized with SDK version 2018.2
  • Subscribers 372 subscribers
  • Views 469 views
prasanth_s
prasanth_s over 7 years ago
i followed the procedure and tried to recover the minized. but on executing the below commmand i get the error
exec program_flash -f flash_only_boot_7007S.bin -fsbl zynq_fsbl.elf -flash_type qspi_single
error :
SF: unrecognized JEDEC id bytes: e5, fc, 1b        Failed to initialize SPI flash at 0:0 (error -2)        Zynq> ERROR: [Xicom 50-186] Error while detecting SPI flash device - unrecognized JEDEC id bytes: e5, fc, 1b        Problem in running uboot        Flash programming initialization failed.        ERROR: Flash Operation Failed
  • stefanrousseau
    0 stefanrousseau over 7 years ago
    I just programmed my MiniZed using the 2018.2 Software Command-line Tool (XSCT) by using your command above.  Usually this works with the Boot Mode switch in the "F" position for boot from flash.  Could you please try the same command, but with the switch in the "J" position?  Just to see if that behaves differently.
    Currently the lastest "restore" document for 2017.4 uses the command:
    exec program_flash -f flash_fallback_7007S.bin -fsbl zynq_fsbl.elf -flash_type qspi_single
    for a fallback image in flash.
