Avnet Boards General How to access SD?
  • Subscribers 374 subscribers
  • Views 632 views
How to access SD?
hai.bi
hai.bi over 14 years ago
In the terminal, where is the sd card that I can write file to?  Thanks.
and how to easily mount a remote windows or linux file system so i can copy files through the ethernet and test the speed of the sd card?
  • hai.bi
    0 hai.bi over 14 years ago
    seems that the whole file system is on the sd card.
  • zedhed
    0 zedhed over 14 years ago
    Hello Hai,
    If you are looking to be able to mount the primary partition on the SD card for read/write capability, take a look at Demo 7 on page 30 of our Getting Started Guide under the ZedBoard documents page.  That demo will walk you through the steps needed to mount the primary partition of the SD card.
    With regards to networking, the Getting Started Guide document also contains a Demo 5 section for Ethernet which starts on page 23 and contains a section covering the use of FTP for transferring files to/from ZedBoard root file system.
    I suggest you investigate these demos and determine if this suits your needs for performance testing.
    -Kevin
    hai.bi,
    You may find this blog post helpful:
    http://zynqgeek.blogspot.com/2012/09/modify-your-boot-image-on-your-zedboard.html
    It describes how to mount the SD-Card, as well as the Ram Disk Image for modification.  There also is a link to a simple tool to help you do this automatically.
