Avnet Boards General Upgrading pzembv to SDx 2017.4
  • Subscribers 372 subscribers
  • Views 520 views
jalejandro
jalejandro over 8 years ago
I'm having trouble upgrading pzembv from 2016.2 to SDx 2017.4.  Is there an upgraded project available or is someone able to provide guidance?  I'm following the steps in UG1146 and UG994:
I used the sdspfm utility to convert the files to the new formats:
  sdspfm_convert c:/pzembv c:/pzembv2 zynq
and now I'm attempting to upgrade the Vivado project to the new version.  I was able to upgrade IP after installing one additional license (color filter array).
There's an error during synthesis related to a fifo core version.  To resolve this I grabbed some updated fifo files from github for onsemi_vita_cam and onsemi_vita_spi as suggested on another forum post (/content/semi-vita-camera-receiver-core-out-date-ip).  Now synthesis completes.
Implementation is failing to meet timing however.  I'm unsure if I need to change some tool settings.  There are two critical warnings in implementation but I'm unsure if they are related.
[Vivado 12-4739] set_clock_groups:No valid object(s) found for '-group[get_clocks vita_clk_div4_l_n_4]'
[Place 30-722] Terminal 'fmc_hdmii_clk' has IOB constraint set to TRUE, but it is either not connectoed to a FLOP element or the connected FLOP element could not be brought into the I/O
Any ideas?
-Jorge
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Jorge,
    Instead of upgrading the IP. My suggestion would be to build everything from scratch in 2017.4
    --Josh
  • jafoste4
    Hello Jorge,
    --Josh
