Avnet Boards General Booting zImage vs. uImage
  • Subscribers 373 subscribers
  • Views 903 views
ejubenville
ejubenville over 12 years ago
I've built u-boot for ZedBoard from the Xilinx git repository.  The include/configs/zynq_zed.h command defines the sdboot to load the kernel from zImage, while the out-of-the box u-boot expects to load uImage (zImage wrapped in u-boot header).
I'm confused by this difference.  Every example I see says that uImage is "required", yet this u-boot source tree seems to require zImage instead.
Can anyone explain the difference?  Where can I get a u-boot source tree that matches the out-of-the-box configuration that requires uImage?
  • zedhed
    0 zedhed over 12 years ago
    Hi ejubenville,
    The more modern way (post 14.2 release) of booting the Linux kernel from U-Boot requires a U-Boot header to be prepended to the kernel using the mkimage tool.  Take a look at this wiki entry which explains this a bit further:
    http://www.wiki.xilinx.com/U-boot
    To answer your other question, if you update to a more recent release tag of U-Boot, there should be an updated zynq_common.h file which contains the changes to use uImage instead of zImage.
    -Kevin
