Avnet Boards General change runlevel on PetaLinux 2014.2
  • Subscribers 374 subscribers
  • Views 809 views
y_okada
y_okada over 11 years ago
I would like to know how to change runlevel (set in /etc/inittab) on PetaLinux 2014.2 or other linux distro working on Microzed.
What I would like to do is to automatically login (without inputting root and password) when booted. So I try to set runlevel to 1 (Singleuser mode).
I prepared following files
- system.dtb : build from PetaLinux
- u-boot.elf : build from PetaLinux
- uImage : build from PetaLinux
- uramdisk.image.gz : made using mkimage from arm_ramdisk.image.gz
- zynq_fsbl.elf : from XSDK
Then, I made BOOT.bin from above files.
I put following files to microSD and booted from microSD.
- BOOT.bin
- image.ub
After booted, I changed /etc/inittab the "initdefaul:" line to 1(single user).
I confirmed that /etc/inittab is correctly changed.
Then I rebooted the PetaLinux and found that the runlevel is still 5 not 1.
How can I preserve the change in runlevel setting?
  • zedhed
    0 zedhed over 11 years ago
    Hi y_okada,
    Keep in mind when you boot your MicroZed in the manner you described above, the uramdisk.image.gz gets decompressed and mounted as the root file system in SDRAM memory.  As a result, that file system is stored in volatile memory during runtime and any changes you make to the file system do not persist following a reboot.
    To make the changes permanent, you would need to modify the /etc/inittab located in the file system within your uramdisk.image.gz image (or arm_ramdisk.image.gz) and then repackage that filesystem again and boot from the updated file system image.  There are some instructions for modifying the RAM disk image in this thread here:
    http://microzed.org/content/how-modify-ramdisk-image-comes-release-145
    -Kevin
  • y_okada
    0 y_okada over 11 years ago in reply to zedhed
    Dear Kevin
    Thank you very much for your reply.
    Now I understand why the change in setting is not effective.
    And the information on how to change uramdisk.image.gz you show me is very helpful.
  • y_okada
    I changed the ramdisk image according to the steps. But it did not change the /etc/inittab.
    I found that the /etc/inittab in PetaLinux booted using microSD and those in ramdisk image were different.
    On the other hand, the inittab file in PetaLinux booted using microSD is same as build/linux/rootfs/targetroot/etc/inittab in Avnet-MicroZed-z7010-v2014.2, which is used to build system.dtb, uImage, u-boot.elf.
    I may make some mistakes related using the ramdisk.
