Avnet Boards General Faster speed grade?
  • Replies 10 replies
  • Subscribers 372 subscribers
  • Views 1307 views
Faster speed grade?
Is it possible to order a Zed Board populated with a faster 7020 (-2 or -3 speed grade)?
Carlos
    Carlos,
    I do not believe that this is available today.  I will look into a timeline and report back as soon as I know.
    Carlos,
    I just checked, and there is no timeline for placing -2 or -3 devices onto the Zedboard.  Currently all boards are being shipped with -1 speed grade IC's and it looks to stay that way for quite some time.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Tim,
    OK. I wanted to use the board for video compression and I need a faster Zynq. The zc702 board from Xilinx also has a -1 device.
    Thanks for your quick reply.
    Carlos
    What is your requirement for speed within the fabric?  Are you looking to use the faster speed grade for the ARM core frequency increase, or the fabric frequency increase?  Are you using our video compression cores, a third party, or your own?
    All, after confirming again with the factory:
    Zedboard = -1 part
    ZC702 = -2 part
    I see news of 1GHz possible on Zync chips.  Can we force an overclock in the toolset?
  • bhfletcher
    0 bhfletcher over 13 years ago in reply to e14 Contributor
    You can, but unless you change to that speed-grade of silicon, it likely will not work.
    Bryan
  • bhfletcher
    I think Tim may have gotten this information from me, so I apologize for the error.  ZC702 will also ship with a -1, as verified at www.xilinx.com/zc702.
    Bryan
    What route should I go to get a quote for a custom order of MicroZed's which have a -2 speed grade on them?
    You can request a custom order by emailing customize@avnet.com
    -Gary
