Avnet Boards General petalinux-v2017.3-final-installer.run
  • Subscribers 377 subscribers
  • Views 881 views
aynilian
aynilian over 8 years ago
I have been trying to upgrade my petalinux by installing the "petalinux-v2017.3-final-installer.run" on my Ubuntu 16.04 machine. I also downloaded the 2017.3 Zedboard BSP.
When I go through the "petalinux-v2017.3-final-installer.run" installation, I had bunch of missing packages which I was able to get by "apt-get update" and "apt-get install -y <missing_package_names>. I was able to get most of them except "xvfb-run" and "textinfo". Has anyone ran into the same issue as you upgraded your Petalinux to 2017.3 and how did you resolve it?
Aynilian.
    0 e14 Contributor over 8 years ago
    Hello Aynilian.
    You need to do the following apt-get:
    sudo apt-get install xvfb texinfo
  • narrucmot
    0 narrucmot over 8 years ago
    Hello Aynilian,
    The previous reply is correct - you will need to run apt-get to install xvfb and texinfo.  In case you run into other issues with your PetaLinux install, you may want to take a look at our VirtualBox Installation Guide, which was last updated for Vivado & PetaLinux v2017.2 (http://zedboard.org/sites/default/files/design/VirtualBox_Installation_Guide_2017_2.zip).  I hope this helps.
    Cheers!
  • aynilian
    0 aynilian over 8 years ago in reply to e14 Contributor
    sudo apt-get xvfb worked
  • vlinux2
    0 vlinux2 over 8 years ago in reply to narrucmot
    The VirtualBox Link is inaccessible. It is endlessly looping.
  • zachpfeffer
    0 zachpfeffer over 7 years ago in reply to vlinux2
    I wrote up how to install VirtualBox on Windows here: https://www.centennialsoftwaresolutions.com/blog/zcu102-development-using-2018-2-on-a-linux-vm-running-on-windows
    The link also includes a list of the packages required to run PetaLinux Tools 2018.2 on the VM on Windows.
    There's also an older write up here [link]
  • jafoste4
    0 jafoste4 over 7 years ago
    Hello vlinux,
    I can access that link, how strange.
    You can find the VM installation guide at the bottom of this web page.
    http://zedboard.org/support/design/18891/146
    --Josh
