Avnet Boards General AXI DMA test errors on Petalinux
  • Replies 9 replies
  • Subscribers 373 subscribers
  • Views 892 views
  • mini-module
  • minimodule
  • zynq
  • mini-module_plus
jarios86
jarios86 over 9 years ago
Hi everyone,
I'm trying to use the axi_dma xilinx driver in order to make transfer between PS and PL in both way. I posted this issue on the xilinx forum but I didn't get any response.
This is the link: https://forums.xilinx.com/t5/Embedded-Development-Tools/AXI-DMA-test-errors-on-Petalinux/td-p/750729
Any idea?? I have looked for across the web but I cannot be able to manage the axidma engine.
Thanks in advance
Best,
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Jarios86,
    For educational support I am going to ask that you ask this question over at the Digilent Forum.
    https://forum.digilentinc.com/
    Also one thing I noticed is you were using Vivado 2016.3 and Petalinux 2016.4. It is always suggest to use matching versions when possible. For instance Vivado 2016.4 and Petalinux 2016.4.
    Josh
  • jarios86
    0 jarios86 over 9 years ago in reply to jafoste4
    Hi @JFoster,
    Now I'm using the same version (2016.3) for both software, Vivado and Petalinux. But the problem persists.
    How can I follow the message in the forum (https://forum.digilentinc.com/) that you posted it. I cannot find the post.
    Best,
    Antonio
  • jafoste4
    Hi Antonio,
    Switching to both using 2016.3 is a good start! I am going to ask that you now repost your question over to Digilent as they are the main point of contact for educational support with the Zedboard.Once you do make your post, if you could please provide a link back to us so we can follow along that would be greatly appreciated.
    Thank you,
    Josh
  • jarios86
    Hi @JFoster
    Sorry, but I'm not using the Zedboard, I'm using the Zynq7100 MMP (Mini Module Plus) board from Avnet.
    Best,
    Antonio
  • jarios86
    0 jarios86 over 9 years ago in reply to jarios86
    Sorry, you mean Zedboard as company or as board?
  • jarios86
    Hi @JFoster
    I have just posted on digilent forum my question.
    This is the link: https://forum.digilentinc.com/topic/3695-axi-dma-test-errors-on-petalinux/
    Best,
    Antonio
  • jafoste4
    Hi Antonia,
    My apologies, for some reason I thought you were using a Zedboard FPGA. I'll take another look at your error.
    --Josh
  • jafoste4
    Hi Antonio,
    Try taking a look at these web links. They all go over how to use AXI DMA
    http://www.fpgadeveloper.com/2014/08/using-the-axi-dma-in-vivado.html
    https://www.xilinx.com/support/answers/57550.html
    Linux Example
    https://forums.xilinx.com/t5/Embedded-Linux/AXI-DMA-with-Zynq-Running-Linux/m-p/522755/highlight/true#M10649
    --Josh
  • jarios86
    Hi Josh,
    I have already seen this links many times. The two first links are for a non linux implementation, they are for standalone, but this is no my case.
    The last one is related for how implement your own driver using the xilinx_dma driver. I checked it few months ago, but I would like tto test first the axi_dma_test in order to ensure that the configuration is fine. But the problem is that I cannot run the axi_dma_test, so I suspect that there is probably something wrong on my configuration, but I don't know what.
    Best,
    Antonio
