Avnet Boards General Avnet Picozed fmc gen 2 and HDMI
  • Subscribers 373 subscribers
  • Views 434 views
pellaca
pellaca over 9 years ago
Hello everybody, I'm trying to bring up a framebuffer device on my zynq X07Z015 to get a graphical interface on an external monitor through the HDMI port.
I'm using Arch Linux with a custom kernel. I compiled the driver for the ADV7511 inside the kernel.
When I fire up the board the FPGA_DONE led turns blue.
Here below [1] you can find the output obtained while booting up the board.
Any help is very much appreciated!
EDIT: If it's of any help, I would also like to add that I loosely followed this tutorial [2]. I successfully compiled a kernel with the driver suggested by the author, but I failed to obtain a working dtb with the additions mentioned on that page. The dts file I created was compiled successfully, but putting it on the micro sd partition replacing the default one resulted in an unsuccesful boot.
[1]https://zerobin.net/?56b84606204f274d#lu1yCy6pvghtArbKejdENCVkwzy98Fj5iYZvrsVOW6Y=
[2]https://wiki.analog.com/resources/tools-software/linux-drivers/drm/hdl-axi-hdmi
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Pellaca,
    Unfortunatly we are no very familiar with the linux console output from ADI's reference designs. The best way to get over your problem is to compare your linux console to an ADI working reference design Linux Console. Here is a working linux console from ADI.
    https://avnet.egnyte.com/dl/SQF4dEnV1L
    You may be able to find additional help with the ADI tutorial you followed over at https://ez.analog.com/
    --Josh
