Avnet Boards General Measuring PWM signal width
  • Replies 7 replies
  • Subscribers 374 subscribers
  • Views 916 views
473srikanth
473srikanth over 9 years ago
Hello Friends,
                            i have to measure a PWM signal with a pulse width ranging from 1msec to 2 msec and the pulse repeatitind frequency is 50Hz. I want to use the ARM A9 processor (PS section) on the zed board to measure it.
                           i have to measure 4 such pwm signals coming from RC receiver.All the 4 signals comes at same time.
How can i measure them ??
Thanks in advance.............
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello 473srikanth,
    You can measure your PWM signal using a oscilloscope. Please take a look at this blog.
    https://www.oscium.com/blog/oscilloscope-measures-pwm-voltage-pt-1
    --Josh
  • 473srikanth
    0 473srikanth over 9 years ago in reply to jafoste4
    Hello JFoster sir,
                                   I want to interface a RC Receiver with the Zed Board for designing a Drone (Zed Board Based Drone). The RC receiver will generate 4 PWM signals with 50Hz pulse repetition frequency and 1msec -2msec pulse width.
    So, i want to measure those pwm signals and process those signals using ZedBoard PS section(ARM A9) for motor control.
    How can i measure the pulse width ??
  • jafoste4
    Hello 473srikanth,
    Please take a look at these references below.
    https://forums.xilinx.com/t5/Xcell-Daily-Blog/Introduction-to-the-Zynq-Triple-Timer-Counter-Part-One-Adam/ba-p/407537
    https://forums.xilinx.com/t5/General-Technical-Discussion/Pulse-Width-VHDL-Code/td-p/125644
    --Josh
  • 473srikanth
    Hello JFoster sir,
    Thanks a lot for the references.
    I must  use TTC timer/counter for measuring pulse widths. For that, i have to use EMIOTTC0CLKI0 for applying the PWM signal.
    EMIOTTC0CLKI0,I1,I2 can be used to apply PWM signals.
    where can i find these EMIO on the Zedboard ??
  • 473srikanth
    Hello JFoster sir,
  • jafoste4
    Hello 473srikanth,
    Please refer to the MicroZed Chronicles issue 9.
    http://zedboard.org/content/microzed-chronicles
    --Josh
  • 473srikanth
    Hello JFoster,
    i found those chronicles and studied the TTC timers.
    i found the Event Control Timer register and Event register in the Registers list of the TTC timer.
    But, when i opened the xttcps_hw.h file , the register map does not include these two registers.
    Then how can i measure the pulse width without these registers??
