Avnet Boards General Can't find the files for the quick start example
  • Replies 8 replies
  • Subscribers 373 subscribers
  • Views 1171 views
  • iiot
  • microzed
  • industrial_iot
  • microzed_iiot
joaomota1994
joaomota1994 over 8 years ago
Hello !
I had to reformat the SD card.
I am trying to finish the quickstart but i don't find the files to execute.
Whenever i plug the SD card to my pc i get 3 different partitions.
I found the Quickstart  files online (here: https://github.com/Avnet/software) and pasted in in both the OVERCBOOT(F:) and one of the other partitions.
When i boot the board i can't find them anywhere
(i placed the zip and unzip folder)
Thanks in advance for the support!
Best Regards
João Mota
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Joao,
    How is the SD Card formatted? FAT 32?
    --Josh
  • joaomota1994
    0 joaomota1994 over 8 years ago in reply to jafoste4
    First, i'm sorry for the delay but i have been homesick for the past week.
    Thanks for the reply!
    Second, yes it is formatted in FAT32. My proccedure was Format the SD card to FAT32 and then burning the image i downloaded of the pulsar8-avnet-microzed7010.img using the win32DiskImager.
    After this the SD card will be partioned in 4 different partitions: OVERCBOOT(with boot info) and 3 other without a name (removable disk).
    I tried formatting one of the others and placing the files there but i can't find them afterwards; i tried placing them in the OVERCBOOT with the same results.
    The board boots nicely from the SD Card and runs it nicely. but the files are nowhere to be found, even when using the find command.
    Thanks for your help!
    What would you recommend me doing now?
    -João Mota
  • jafoste4
    Hell Joao Mota,
    Are you following the "Wind River Pulsar Linux OS Download Instructions" located here?
    http://zedboard.org/support/documentation/1519
    --Josh
  • joaomota1994
    Originally i was following the instructions that came in the box (the starter kit) then somehow i screwed up (if needed there are other posts made by me, but it wasn't set to boot from SD)
    Now i can say that yes i'm following that instructions for the  "Wind River Pulsar Linux OS Download Instructions"
    I downloaded the pulsar8-avnet-microzed-7010.img.zip and burnt it to the SD card as expected.
    I'm able to boot from it but i don't have the files there. I only need to download that image that i mentioned above, correct?
    Best regards and thanks for the patience,
    João Mota
  • jafoste4
    Hello Joao,
    What files exactly are you not seeing on the SD Card?
    --Josh
  • joaomota1994
    Hey
    I'm not seeing the Demo projects that should be there
    The IIOT_QuickStart_Demo executable that i should be able to run after login as said in the quick start guide
    -João Mota
  • joaomota1994
    0 joaomota1994 over 8 years ago in reply to joaomota1994
    i've already paste those files inside the SD card but i can't access them from the board. Where should the be or where should i paste them or how are they suppose to appear there?
    -João Mota
  • joaomota1994
    Here i downloaded them and sent them to the board.
