Avnet Boards General Is Zedboard broken?
  • Subscribers 373 subscribers
  • Views 592 views
Is Zedboard broken?
e14 Contributor over 8 years ago
Plugged in power, inserted SD card with out of box image, modified jumper to boot from SD card according to the instructions: http://zedboard.org/content/zedboard-out-box-sd-card-image-and-source
After turning on the power via SW8, LD12(Done) and LD00-LD07 (led above physical switch) flashes for a split second. LD13(Power) led never becomes green. UART cannot connect to PC.
The power source if reliable and tested with another device. The zedboard appears to be either turning off / losing power quickly.
Is there any way to debug what might have gone wrong?
  • jafoste4
    0 jafoste4 over 8 years ago
    hello jack,
    Is this a new zedboard or one that has benn used for a while?
    --Josh
    0 e14 Contributor over 8 years ago in reply to jafoste4
    Hi JFoster,
        This Zedboard has not been turned on for about 2-3 years. It was reported to be working at that time.
    Jack
    Hi JFoster,
    Regards
    Jack
    Jack
  • jafoste4
    Hello Jack,
    You could try probing all the power rails to determine what rail is malfunctining. My other suggestion is, if this is for education purposes please contact Digilent as they are responsible for educational support.
    --Josh
