Avnet Boards General No linux image on boot
  • Replies 8 replies
  • Subscribers 373 subscribers
  • Views 674 views
catherineh
catherineh over 13 years ago
I'm starting my ZedBoard for the first time, and I don't see anything in Tera Term.
It appears in my Device Manager as "Cypress Serial", and windows thinks that the driver is up to date. LD13 and LD12 are both on, but there is no activity on LD11. My serial connection settings are:
Baud Rate: 115200
Data: 8 bit
Parity: none
Stop: 1 bit
Flow control: none
Transmit Delay 10 msec/character, 100 msec/line
I've turned it off and on several times, but there is nothing in the terminal. I'm not sure what to do next.
  • bhfletcher
    0 bhfletcher over 13 years ago
    Are you booting from SD Card? Did you double-check the jumpers (MIO[2:6])? What files do you see on the SD Card if you read it from your PC?
    Bryan
  • catherineh
    0 catherineh over 13 years ago
    The SD card looks fine, it contains the files:
    ramdisk8M.image.gz
    BOOT.BIN
    devicetree_ramdisk.dtb
    README
    zImage
    The MIO pins are set to:
    MIO 6: set to GND
    MIO 5: set to 3V3
    MIO 4: set to 3V3
    MIO 3: set to GND
    MIO 2: set to GND
    and the LD12 is on, so I assume everything is working.
  • catherineh
    Oh, and DISP1 is showing the digilent logo
  • catherineh
    hmm, I've tried connecting with putty as well and it just gives me a "ding dong something is wrong" noise.
  • catherineh
    It works on a mac with usbmodem, so it seems like I'm having a windows issue.
  • bhfletcher
    I'm using Win7, and it is fine. Have you followed the Cypress USB-to-UART Setup Guide Rev. 1.1 on the Documentation page?
      Bryan
  • catherineh
    derp derp, turns out just needed to hit enter a couple of times in tera terminal. Well now I feel stupid.
    I have the same issue too, but hitting <enter> in the terminal doesn't help. Please let me know if I am missing something
