Avnet Boards General Related to block design in vivado....
  • Subscribers 373 subscribers
  • Views 841 views
mayurishinde
mayurishinde over 8 years ago
Hello Everyone,
I am trying to edit IP in block design.. but m not getting how to do that,...
When I use the IP as RTL code then I can edit the the source file using some tcl commands.
so, How to edit the IP CORE when I used it in the block design?
Please Guide..
Thank you.
  • jafoste4
    0 jafoste4 over 8 years ago
    Once you add the IP block into your block design you can then double click on the IP block. This will open a customization window that will allow you to modify various parameters.
    What development platform are you using?
    -Josh
  • mayurishinde
    0 mayurishinde over 8 years ago in reply to jafoste4
    Actually I want to make some changes in source files of IP, other than customization parameters.
    In vivado, I am able to edit this source files when I used that xilinxs IP as a RTL code. But I am not getting how to modify the code when we use that IP in block design?
  • jafoste4
    Please refer to https://www.xilinx.com/support/answers/57546.html
    --Josh
  • mayurishinde
    Thank you..
    I tried this for editing IP CODE when i use it as a RTL code, it works. But still I am not getting when I use that Xilinx IP in block design.
    Will you please explain how modify IP Source files when IP used in block design?
  • mayurishinde
    Thank you..
  • jafoste4
    I typically don't modify the existing IP, so you may be able to get additional support at the XIlinx forum. Please ask this question at the Xilinx forum and post a link back to I can follow along.
    Thank you,
    Josh
