Avnet Boards General Problem encountered in SpeedWay Training Course - Introduction to Zynq
  • Subscribers 373 subscribers
  • Views 677 views
I encountered a problem when doing Lab01 of SpeedWay Training Course - Introduction to Zynq.
After I filled in "system" as the module name of the embedded sources, XPS could not open. Instead, PlanAhead showed an error:
[Common 17-49] Internal Data Exception: xps application failed!
I am using PlanAhead 14.4.1 with a Webpack license.
Do I need to revert to version 14.2 in order to finish the lab, or is there a bug in version 14.4.1?
Thank you!
    I found the solution!
    The problem is addressed here:
    http://forums.xilinx.com/xlnx/board/crawl_message?board.id=PABD&message.id=1437
    By removing the spaces in the file path I fixed it.
    I have no spaces in the file path.
    It looks like this:
    C:UsersVKondagunturiDocumentsVarunZEDZYNC_LABS
    It still shows the error [Common 17-49] Internal Data Exception: xps application failed!
    Any other suggestions will be helpful
