Avnet Boards General problem with HDMI interfacing to zedboard
  • Subscribers 373 subscribers
  • Views 405 views
Hi ,
we have a problem with hdmi interfacing to zedboard. we are unable to communicate with hdmi on zedboard. we are using hdmi display controller provided by Avnet.
ZedBoard_HDMI_Display_Tutorial_2014_1_20140623.zip
we sucessfully generated bitstream file and we tried to run the baremetal application code on zedboard which is provided by Avnet, but i did not get any display on the screen. we have followed the procedure which is mentioned in the tutorial document.
please suggest a solution for this problem.
Thanks & Regards,
Srinivas Rao
  • albertabeef
    0 albertabeef over 11 years ago
    One common mistake with this tutorial, when also using a FMC-IMAGEON module, is to expect the color bars on the FMC modules's HDMI output connector.  Can you please confirm that you have your monitor connected to the ZedBoard's HDMI connector ?
    Can you confirm that your monitor supports 1080P60 resolution ?
    Mario.
    The monitor does not seem to supporting 1080P so I made some changes in their c code andchanged their paramters to 720P. It still does not show anyhting on the monitor. Can you please help me?
