Avnet Boards General MicroZed communicating to FX2 cypress device
  • Subscribers 374 subscribers
  • Views 444 views
Set-up:
I have MicroZed board that has Nexus 3 development board connected to it though USB. Nexus 3 board has CY7C68013A-56LTXC(FX2) chip on it, which is used to communicate to MicroZed.
Problem:
The problem that I am seeing is when I use command "lsusb" on MicroZed it returns "Bus 001 Deice 002: ID 04b4:8613" which is correct vip and vid for this device but it does not identify my device.
Question:
I was hoping that some one here could explain to me how can I get the driver for Cypress FX2 devices installed on my MicroZed board.
Note: When I use Ubuntu and use command "lsusb" while having nexus 3 connected to it I get "Bus 003 Device 015: ID 04b4:8613 Cypress Semiconductor Cor. Cy7C68013 Ez-USB FX2 USB 2.0 Development Kit."
  • zedhed
    0 zedhed over 11 years ago
    Hi artem-b,
    Please correct me if I am wrong, but it sounds like you are using MicroZed to try and configure the FPGA on your Nexus 3 board.
    From what I remember of the days when we used Cypress FX2 for accessing FPGA configuration ports, that device is highly configurable.  I think the intention for the use case here is that the FX2 is used to configure the FPGA:
    https://www.digilentinc.com/Data/Products/NEXYS3/Nexys3_rm.pdf
    You may need to contact Digilent to confirm this but have you tried using the Adept software on your Linux PC to access the Nexus 3 board?  If that works okay, I see that the Digilent folks now have a version of Adept that runs on Raspberry Pi so that might be something that you can leverage to get the Adept drivers running on your MicroZed:
    https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,66,828&Prod=ADEPT2
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    Hey Kevin,
    I actually have a custom FW for CY7C68013A-56LTXC(FX2) Cypress chip to communicate with the FPGA. The problem that I need  help with is figuring out how to install drivers for CY7C68013A-56LTXC(FX2) chip on MicroZed. Currently when I used ls usb on MicroZed I get "Bus 001 Deice 002: ID 04b4:8613" which means that MicroZed have found the device but it does not have the driver for it.
    Note: When I use lsusb on my PC which came with pre installed drivers it displays "Bus 003 Device 015: ID 04b4:8613 Cypress Semiconductor Cor. Cy7C68013 Ez-USB FX2 USB 2.0 Development Kit."
    Artem
  • zedhed
    Hi artem_b,
    Have you checked to see if there is support for that device withing the kernel source tree already?
    What Linux distro are you using on your PC where the drivers were pre-installed?
    -Kevin
