Avnet Boards General Communication of I2C devices with Zedboard
  • Subscribers 373 subscribers
  • Views 1157 views
  • iiot
  • microzed
  • industrial_iot
  • microzed_iiot
bart23
bart23 over 8 years ago
As I am a beginner in Zedboard - ZynqRegistered-7000
I need to know
How should I install the I2C library in zedboard to create the communication between I2C sensors and Zedboard
Is there any tutorial which will guide us to use the I2C protocol with Zedboard
your suggestions will be very helpful
Thank you
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Bart,
    You need to make a vivado project to add a I2C controller. The controller can either be in the programmable logic or the Processing System. THen when you export your bitstream to SDK the drivers will be imported into your project.
    --Josh
  • bart23
    0 bart23 over 8 years ago in reply to jafoste4
    Any tutorial for learning about Vivado project to add I2C Controller ???
    My major aim is to interface zedboard montoring system using Sensor with 4-20mA transmitter
  • jafoste4
    Hi Bart,
    Please refer to Tutorial 07 and 08 http://zedboard.org/support/design/18891/146
    These two tutorials showcase using either a PS or PL I2C controller.
    --Josh
