Avnet Boards General Ubuntu Desktop Linux Turorial with Vivado 2015.1
  • Subscribers 374 subscribers
  • Views 577 views
I followed the Ubuntu Desktop Linux Turorial with Vivado 2013.4 and everything work. But now, I would like build the project with Vivado 2015.1 and I have some problems. I modified some scripts for builded the project and I finally achieved to generate the bitstream and made all files for run Ubuntu. The problem is when the Kernel is running I have this message :
adv7511-hdmi-snd fpga-axi@0: adv7511_hdmi_snd: ASoC: CODEC DAI adv7511 not registered
and the desktop not appear on the HDMI screen but Linux work because I can communicate with it through UART.
I think I have forgotten to modifie something but what ? Have you any idea ?
Jo
  • zedhed
    0 zedhed over 11 years ago
    Hi Jo,
    Going from Vivado 2013.4 to 2015.1 is a big leap.  It sounds like you upgraded the hardware project, did you also move to a more recent release of Linux kernel?  I think that is important because any change in the underlying hardware memory map needs corresponding support in the Linux driver.
    I think ADI shows support for this hardware with 2014.2 and they may also support 2014.4 also:
    http://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511
    Is there a specific reason that you need to use 2015.1 tools?
    -Kevin
    Hi Kevin,
    Thanks for your answer.
    I have no choice, my company impose me Vivado 2015.1
    Jo
    I solved my problem, the interrupt ID have changed so I modify the devicetree and everything work.
    Jo
    i just want add uartlite and drive it in linux,but i met a lot of trouble like
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Error: unrecognized/unsupported machine ID (r1 = 0x00000000).
    Available machine support:
    ID (hex)        NAME
    00000d32        Xilinx Zynq Platform
    Please check your kernel config and/or bootloader.
    I don't know how to fix it
