Avnet Boards General How to change CPU_1x Frequency to 1MHz??
  • Subscribers 373 subscribers
  • Views 462 views
473srikanth
473srikanth over 9 years ago
Hello Friends,
i'm using Triple Timer Counter of Zed Board for my application. When i'm using TTC in Event Timer operation mode,  the TTC is counting the external pluse with at a rate of CPU_1x.
Can we change this CPU_1x (to 1MHz)  for the Zed Board??
what are the minimum and maximum CPU_1x frequency for zed board??
Thanks in advance....
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello 473srikanth,
    The minimum speed is 50MHz and maximum speed is 667MHz. I found this information by opening up the Zynq block in my block design then clicking Clock Configuration. There you will find the max and min frequency for your CPU.
    --Josh
