Avnet Boards General mating PMOD connectors
  • Subscribers 373 subscribers
  • Views 468 views
I'm looking for a good supplier of mating 12-pin PMOD connectors or cable assemblies for the Micro-Zed I/O Carrier Card.  Any help would be appreciated.
    The PMOD connectors on all Avnet boards are P/N Samtec SSW-106-02-F-D-RA.  As you can see from that website, samtec makes lots of mating connector options.  Are you looking for mating boards or cables?  If you reply here, I can help you narrow down your needs.
    I was looking for cables that I could plug into the existing PMOD connector to interface the MicroZed (via the I/O carrier board) with our prototype RF hardware, using the Microzed as a controller / test fixture. I found a suitable mating cable from SAMTEC. I wound up with IDMD06-S-18.00-T-ST.
    Thanks for the reply.
    - Neil
