Avnet Boards General Problem with XAPP1093
  • Subscribers 372 subscribers
  • Views 348 views
lukwolf
lukwolf over 12 years ago
Hi!
I am trying to run the project
http://www.xilinx.com/support/documentation/application_notes/xapp1093-amp-bare-metal-microblaze.pdf
I follow all the steps and Zedboard does nothing after loading the boot.bin (no output, blue LED no power on, etc..). Besides, does not work with the boot.bin generated by the author.
The Zedboard works perfectly and is in SD mode and can load other boot.bin without problem.
Someone knows I do wrong? Someone has some project with a MicroBlaze that works? Thank you very much
  • bhfletcher
    0 bhfletcher over 12 years ago
    The listed XAPP1093 is intended to work with the ZC702. The ZC702 boot.bin files are not directly compatible with ZedBoard. You will have to update the project to match ZedBoard and then rebuild and regenerate all the files.
    Bryan
