Avnet Boards General LVCMOS33 support?
  • Subscribers 373 subscribers
  • Views 572 views
  • mini-module
  • minimodule
  • zynq
  • mini-module_plus
LVCMOS33 support?
gaochangw
gaochangw over 8 years ago
I am trying to use Zynq-MMP 7100 to receive data from a PMODMIC3 microphone using SPI protocol but failed. The microphone need 3.3V power supply but I found no 3.3V port on either JX1 or JX2. I wonder if it's possible for MMP to support LVCMOS33? Or do you suggest me to change a microphone. Thank you so much!
Best,
Chang
    0 e14 Contributor over 8 years ago
    If you are using the Avnet MMP Baseboard2 with your Zynq MMP, you can set the FMC_VADJ rail on the Baeboard2 to 2.5V or 3.3V via SW15 switch. If you are using your own Baseboard, you can drive the Zynq MMP JX1_VCCIO_SE or JX2_VCCIO_SE with 3.3V supply.
  • gaochangw
    0 gaochangw over 8 years ago in reply to e14 Contributor
    Thank you so much!
