Avnet Boards General Problem with elf files
  • Subscribers 373 subscribers
  • Views 658 views
I have just installed the Xillinux distribution in my zedboard, so that I can have access to my RAM. When I tried to run the elf executables by typing ./test.elf i got this message,instead of running and print me the "hello world" message:
root@localhost:~/Desktop# ls
test.elf
root@localhost:~/Desktop# ./test.elf
-bash: ./test.elf: No such file or directory
Could you please help me?
    It looks like you tried to run a program that was compiled as a bare-metal application on Xillinux. Or with a compiler that otherwise generates a binary that is incompatible.
    Note that you can natively compile a C program on the board itself, by using "gcc" and "make" inside Xillinux. It's slower than doing that on a fullblown computer, but it guarantees to create a binary that matches the environment's libraries.
    And for the curious, here's the super-long answer to your question:
    http://billauer.co.il/blog/2014/06/arm-linux-dynamic-loader/
       Eli
    Hello Eli,
    thank you for your prompt answer.
    Can you please be more specific about how can I overcome this problem. I tried to follow your instructions in the link given, but I didn't make it out.
    Thank you in advance,
    Nicholas
    I should also mention that i am using the xilinx SDK running in windows and I have just installed the Xillibus distribution to my zedboard. While I was using the same infrastructure with the previous linux distribution I didn't face problems. My elf files (e.g. test.elf)was running in my board normally after typing ./test.elf .
    Nicholas
