Avnet Boards General Tutorial - Zedboard HDMI Display Controller
  • Subscribers 372 subscribers
  • Views 360 views
Hi. I was trying out the tutorial for the Zedboard HDMI Display Controller Tutorial for Vivado 2013.3 here: http://www.zedboard.org/support/design/1521/11
And I got up to the point of generating bitstream. The error that occurs is:
"ERROR: [Common 17-69] Command failed: this design contains one or more errors for which bitstream generation is not supported: v_cresample"
I've installed the necessary evaluation license files for Vivado HLS, for Petalinux, for the ISE WebPack. And redid the entire tutorial, but I am still getting the error.
  • albertabeef
    0 albertabeef over 12 years ago
    Heidi,
    Did you Licensing the Video and Image Processing Pack IP Cores, as described in the tutorial document ?
    Make sure that you have a valid "hardware evaluation" license for the Chroma Resample core.
    In the Xilinx License Configuration Manager, for the v_cresample feature, you should see the following:
    IP:Hardware_Evaluation
    Also, the expiration date must be in the future.
    Mario.
