Avnet Boards General uzed uart driver installs as mouse driver instead
  • Subscribers 375 subscribers
  • Views 509 views
smvo555
smvo555 over 11 years ago
Hi All,
Sometimes when connecting the uZed (mine is connected to the break out carrier card most of the time) to a computer the device driver for the Silicon Labs CP2104 USB-to-UART installs as a mouse and then the cursor starts jumping around the computer screen and clicking on things. This has happened a number of times on several different computers running windows 7 and windows xp.
Does this happened to anyone else? If so, is there a way to prevent it from happening?
Sam
  • zedhed
    0 zedhed over 11 years ago
    Hi Sam,
    I have seen this behavior before and have put some research into it.
    This forum thread here seems to confirm the same problem comes from a number of CP210x family devices not just the CP2104 on MicroZed:
    http://community.silabs.com/t5/8-bit-MCU/WinXP-thinks-CP2102-is-a-mouse/td-p/76415
    From what I have seen, the problem has surfaced most often when my MicroZed application is streaming a high rate of character data out to the console.  While streaming out text, the USB-UART port is enumerated under Windows as a COM port.  That streaming data on the COM port tricks Windows into thinking that you just connected a mouse (remember back to the days when you would plug your serial mouse into a COM port on the back of the PC?) and that is when you start seeing your cursor bounce around the screen.
    The forum post I mentioned suggests a way to disable the Windows PNP enumeration but I have not tested that to see if it actually helps avoid the effect you are seeing.
    -Kevin
  • smvo555
    0 smvo555 over 11 years ago
    thanks for your response, I'll look into this further.
    Best,
    Sam
  • y_okada
    0 y_okada over 11 years ago
    From my experience, this happens not only for microzed uart, but also for other device using uart, which continuously output text in some intervals.
    To avoid this, I have disabled the mouse driver mistakenly detected by Windows OS.
    Similar Q and A can be found at superuser:
    http://superuser.com/questions/341630/gps-detected-as-serial-mouse
