Avnet Boards General Getting Started with Embedded Linux - Zedboard
  • Subscribers 373 subscribers
  • Views 398 views
I try to build the Linux Kernel (https://www.digilentinc.com/Data/Products/EMBEDDED-LINUX/ZedBoard_GSwEL_Guide.pdf)
root@asus-N550JV:~/linux-digilent# make ARCH=arm digilent_zed_defconfig
# configuration written to .config
root@asus-N550JV:~/linux-digilent# make ARCH=arm menuconfig
scripts/kconfig/mconf Kconfig
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: 'include/generated/mach-types.h' is up to date.
  CC      kernel/bounds.s
gcc: error: unrecognized argument in option u2018-mabi=aapcs-linuxu2019
gcc: note: valid arguments to u2018-mabi=u2019 are: ms sysv
gcc: error: unrecognized command line option u2018-mlittle-endianu2019
gcc: error: unrecognized command line option u2018-mno-thumb-interworku2019
/root/linux-digilent/./Kbuild:35: recipe for target 'kernel/bounds.s' failed
make[1]: *** [kernel/bounds.s] Error 1
Makefile:815: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
What are the error?
    Avnet does not provide any support for Digilent Embedded Linux. The Digilent distribution is intended only for students. Please contact your professor or Digilent support at support@digilentinc.com
    Please refer to https://github.com/Xilinx for ZedBoard Linux.
    -Gary
