Avnet Boards General USB UART powered down with power switch
  • Subscribers 372 subscribers
  • Views 791 views
When the ZedBoard is powered down, it also powers down the Cypress UART connection and thus the host looses the virtual comport. The result is that you have to reconnect in your terminal application after you have powered the board up again with the possibility of losing a part of the output.
It seems this can be prevented by removing R146 and placing R147. Why is this not the default?
Kind regards,
Maarten
  • bhfletcher
    0 bhfletcher over 13 years ago
    You could do that, but it's not necessary. The Cypress USB-UART driver has a persistent feature built-in. Once you have connected to your terminal, leave the terminal connected when you power down, when you power back up, the terminal will automatically reconnect.
    Bryan
    PuTTY will disconnect the moment the power is down and the port gone. It will not auto-reconnect.
  • bhfletcher
    0 bhfletcher over 12 years ago
    Just to close the loop on this, Cypress has released a new driver, and we have updated the USB-UART documentation for ZedBoard.
    Bryan
    Could you be so kind to add a link to where this new driver can be found?
    There is a link to the driver and installation instructions in the current revision of the Cypress USB to UART Setup Guide located on the ZedBoard documentation page:
    http://www.zedboard.org/documentation/1521
    -Gary
