Avnet Boards General Using Python 300 with Python 1300 Camera Module
  • Subscribers 373 subscribers
  • Views 1112 views
tktx
tktx over 9 years ago
I'm looking for an eval board for a Python 300, and came across Avnet's Python 1300-C Camera Module (plus MicroZed and Embedded Vision Carrier Card).
Would you anticipate any problems with swapping out the Python 1300 part with a 300? I'm fairly sure they are pin compatible.
On a related note, I see that the Python part interfaces to the MicroZed through Avnet's Camera Interface. Can the MicroZed access the Python's control registers (SPI) through this interface?
Thanks.
  • albertabeef
    0 albertabeef over 9 years ago
    tktx,
    You are correct, the PYTHON camera module PCB can accomodate both ISP8 packages : 48LCC & 84LCC.
    This covers the PYTHON image sensor family up to PYTHON-5000.
    However, Avnet only has the PYTHON-1300 image sensor available in production.
    Mario.
  • tktx
    0 tktx over 9 years ago in reply to albertabeef
    That's great. Thanks for confirming.
    Do you have any thoughts on whether Avnet's Camera Interface will give me access to the Python 300's full set of configuration registers?
    Thanks again.
    -Tom
  • jothin
    0 jothin over 8 years ago in reply to tktx
    I am trying to interface with Python-500. I use avenet reference design. I get Python-300 is detected. What are the registers to be modified for python-500.
    Jothi
  • jothin
    0 jothin over 7 years ago in reply to jothin
    Any Linux drivers for Python 1300 sensor?
