Avnet Boards General Problem with Triple Timer Counter Low Level example
  • Subscribers 372 subscribers
  • Views 363 views
473srikanth
473srikanth over 9 years ago
Hello Friends,
                      I'm working with zed board's Triple Timer Counter and i executed TTC low level example that will generate a square wave on Waveform output pins. I Found that, even after the execution of the program , the waveform output continues to come without termination. There is no infinite loop in the example code.
                    Can anyone help to solve this issue of terminating the wave after completion of execution ??
Thanks in advance.....
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Srikanth,
    I am going to suggest that you ask this question over at Xilinx as it is their example code you are referencing. They will have more experience in supporting this example code.
    https://forums.xilinx.com/
    --Josh
