Avnet Boards General Hi how can I view a zedboard output in CRO?
  • Subscribers 371 subscribers
  • Views 605 views
yonder
yonder over 7 years ago
  • juliediane
    0 juliediane over 5 years ago
    Hi, I have the same question. when you find a solution. then tell me.
    0 michaelkellett over 5 years ago in reply to juliediane
    Perhaps if you explain the question a bit better it might be possible to help you (both).
    What kind of output are you looking at.
    Assuming by CRO you mean a Cathode Ray Oscilliscope (kind of old fashioned term - (almost) no one makes the ones with actual tubes in any more.) :
    You can look at signals on a scope - that's easy, if you have  a modern scope it may be able to decode serial protocols.
    It is possible to display text on a standard scope screen by making the right kind of signals (and this might be easier on one with a tube than on modern LCD types.)
    So, please explain in a bit more detail what you are trying to do and suggestions may be forthcoming.
