Avnet Boards General Arduino Carrie Card
  • Subscribers 372 subscribers
  • Views 516 views
Arduino Carrie Card
addint96
addint96 over 7 years ago
Hello, i am using a Microzed with a MicroZed Carrier Card kit for arduino and i am having problem with the constraint, i have no idea how to find out the port of the microZed to connect to the ports, for example, the PL PMOD J3. How can i know to what refenrence each pins (G18.JX2_LVDS_14_N.JX2.63.D0_N, G17.JX2_LVDS_14_P.JX2.61.D0_P, for example)?
i dont know if i am explaining correctly or not, but thanks in advance.
  • jafoste4
    jafoste4 over 7 years ago in reply to jafoste4 +2 suggested
    I would also take a look at the following reference designs. MicroZed 7853.contentimage_204928.png -Josh
  • jafoste4
    jafoste4 over 7 years ago +1
    Hi, Are you referring to what pins these refer to on the Zynq Device? I typically just pull up both the carrier card schematic and SOM schematic and trace the PL PMOD signals back until I hit the SOM to…
  • jafoste4
    0 jafoste4 over 7 years ago
    Are you referring to what pins these refer to on the Zynq Device? I typically just pull up both the carrier card schematic and SOM schematic and trace the PL PMOD signals back until I hit the SOM to find out which pin it corresponds to.
    -Josh
  • jafoste4
    0 jafoste4 over 7 years ago in reply to jafoste4
    -Josh
