Avnet Boards General OpenCV Vitis - Minized
  • Subscribers 373 subscribers
  • Views 1231 views
  • Using Xilinx Tools
  • Software Application Development
  • MiniZed Hardware Design
bartokon
bartokon over 6 years ago
Hi!
I have problem linking OpenCV for minized acceleration in Xilinx Vitis.
Related post: https://forums.xilinx.com/t5/Vitis-SDAccel-and-SDSoC/OpenCV-platform-in-Vitis/td-p/1075256
BSP: Petalinux - MiniZed packages not visible rootfs
Do you know how can I link those packages to Vitis? and If so could you provide tutorial or link to solution?
I have tried many solutions found in web but still no luck image
Thanks.
  • clem57
    0 clem57 over 6 years ago
    bartokon You need to follow https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1144-petalinux-tools-reference-guide.pdf to install opencv into PetaLinux
  • bartokon
    0 bartokon over 6 years ago in reply to clem57
    Hello Clem,
    I have installed sysroots like this:
    petalinux-package --sdk and then ./sdk.sh. I have chose cortexa9t2 as my sysroot for project in Vitis project and that doesn't work.
    I have two more questions besides original one.
    First, for what is "x86_64=petalinux-linux" folder for because I'm not using it in any way?
    Second, will following page 115-Examples fix libraries problem by adding qt toolchain? or the effect will be the same as starting from "2.Building OpenCV applications."?
    Thanks for responding!
  • bartokon
    I have followed steps included in petalinux-tools-ref-guide but still it doesn't work. It must be some problem with linker...
  • bartokon
    The problem was with Vitis auto include libraries they would collide with those included in petalinux rootfs.
    I have deleted "includes vivado hls libraries" in GCC Host Compiler options and now openCV works perfectly.5187.contentimage_206111.png
