Avnet Boards General Avnet extended vs industrial temperature range
  • Subscribers 371 subscribers
  • Views 663 views
  • ZedBoard General Questions
  • Ultrazed Hardware Design
mohamed.abdelaziz
mohamed.abdelaziz over 6 years ago
I was checking ultrazed EG board and found AES-ZU3EG-1-SOM-I-G and AES-ZU3EG-1-SOM-G boards.
after checking data sheet. the only difference is that  the " I " stands for industrial grade.
what is the difference between industrial and extended grade?
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    The only real difference is the MPSoC.  The I grade has an I grade MPSoC and the E grade has the E-grade version.  The rest of the board stays the same.
    NOTE that the least common denominator for the board is 85C.  So, while the MPSoC and a few other components are rated higher, we do not rate the SOM higher than 85C.
    I grade MPSoC parts operate from: -40C to +100C
    E grade MPSoC parts operate from: 0C to +100 or +110C depending on the specific part
    Check out the datasheet DS891 page 40:
    https://www.xilinx.com/support/documentation/data_sheets/ds891-zynq-ultrascale-plus-overview.pdf
    For the exact specifications.  As always, with any design, you will want to run through a thermal analysis of the parts, boards, and your design using all the tooling / estimators / etc. to ensure your design will be able to properly hit the thermal thresholds.  Pay special attention to any power supplies and the MPSoC itself.
    --Dan
