Avnet Boards General Does the UltraZed-EV SOM support PCIe Gen3x16 on the PL side?
  • Subscribers 372 subscribers
  • Views 604 views
  • Using Xilinx Tools
  • ZedBoard General Questions
  • Ultrazed Hardware Design
  • Zedboard Training
jwong_zendar
jwong_zendar over 6 years ago
This is in regards to UltraZed-EV SOM.
Would I be able to build a custom carrier card that brings out the PCIe interface on the PL side?
  • drozwood90
    drozwood90 over 6 years ago +2 verified
    Hi there, If you built your own carrier card, you could bring the transceivers out to a PCIe Gen 3 x16. The Hardened IP does support this capability. Note that if you are using this as a PCIe Endpoint…
  • jwong_zendar
    jwong_zendar over 6 years ago in reply to drozwood90 +1 suggested
    Thanks for the quick reply Dan! I do plan to use this as a PCIe Endpoint and possibly use Tandem PCIe to accomplish meeting the BIOS PCIe enumeration time.
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    Note that if you are using this as a PCIe Endpoint, there are some caveats in doing this and you will want to ensure you check out the PCIe and other transceiver documentation - especially around potentially needing Partial Reconfiguration to get the PL loaded up fast enough to register with the PCIe Root complex.
    --Dan
    Make sure to mark answered if my reply has answered your question- Thanks!
  • jwong_zendar
    0 jwong_zendar over 6 years ago in reply to drozwood90
