Avnet Boards General Cannot run Hello World
  • Subscribers 373 subscribers
  • Views 2707 views
  • Using Xilinx Tools
  • hello-world
  • newbie
  • MiniZed Hardware Design
  • minized
nwerneck
nwerneck over 5 years ago
Hello, I recently got myself a MiniZed board, and I'm taking my first steps learning to use it. I work an an Ubuntu machine, and I have installed the Xilinx Vitis 2020.1 unified platform.
I managed to create a project on Vivado and open on Vitis, although when I try to run the debugger I get this error message in a window:
Error while launching program:
Could not find ARM device on the board for connection 'aoeu'.
Check if the target is in:
1. Split JTAG - No operations are possible with ARM DAP.
2. Non JTAG bootmode - Bootrom may need time to enable DAP.
Please try again.
Troubleshooting hints:
1. Check whether board is connected to system properly.
2. In case of zynq board, check whether Digilent/Xilinx cable switch settings are correct.
3. If you are using Xilinx Platform Cable USB, ensure that status LED is green.
I have already tried to install the cable drivers.
Is it even possible to use this board with the 2020.1 tools or should I move back to the 2019 or 2018 ones? And how can I try to debug this issue?
  • bartokon
    bartokon over 5 years ago +1
    Check if you have proper cable. Few times I have used power-only cable from phone for minized and I couldn't communicate with it. Are you able to program fpga? Is Vivado detecting your board?
  • nwerneck
    nwerneck over 5 years ago +1 verified
    To answer my own question... The problem I had was that the board boot mode was set to F, it should be J. TIL...
  • bartokon
    0 bartokon over 5 years ago
  • nwerneck
    0 nwerneck over 5 years ago
  • nwerneck
