Avnet Boards General zedboard for resnet 50 by using vivado 2020
  • Subscribers 373 subscribers
  • Views 1209 views
muhammetalia
muhammetalia over 5 years ago
I want to use zedboard for resnet 50 by using vivado 2020.2 but the recent design didn't work for which it was designed in vivado 19.2 can I reach the zedboard bd in vivado
  • narrucmot
    narrucmot over 5 years ago +1
    Hi Muhammet, I am not sure I understand what you re trying to ask. Updating a Vivado design from an older version (2019.2) to a current version (2020.2) is often possible, but may require some work to…
  • drozwood90
    0 drozwood90 over 5 years ago
    Hi there,
    We have not released 2020.2 support at this time.  We also do not support ZedBoard with Resnet50.  Is this something that you downloaded somewhere else?  If so, you should probably ask this question where you downloaded the example from.  I do know that Digilent handles ZedBoard software support for newer packages.  The software support that I work with is on the product page.  You can try your question over at the Digilent support forums.  There are many more users of the ZedBoard there and you stand a better chance of receiving the answer you seek.
    Second, what I can offer, you mention 2019.2 and 2020.2.  If the example AI design is from 2019.2, you have to use the 2019.2 tools. The AI libraries are very tool version dependent.  If the design is not using AI Vitis libraries, then I would still highly suggest using the matching version of tool for the design.
    Is there a reason you cannot use the version of tool that the design was created for?
    --Dan
  • narrucmot
    0 narrucmot over 5 years ago
    Hi Muhammet,
    I am not sure I understand what you re trying to ask.  Updating a Vivado design from an older version (2019.2) to a current version (2020.2) is often possible, but may require some work to update IP blocks.  If you still have Vivado 2019.2 you can open the project and export the block design (bd) and then use that to try and recreate the design in Vivado 2020.2.  You may find these Vivado TCL resources helpful:
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug894-vivado-tcl-scripting.pdf
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug835-vivado-tcl-commands.pdf
    --Tom
  • muhammetalia
    0 muhammetalia over 5 years ago in reply to narrucmot
    Thanks for quick reply.
    I have seen this answer from xilinx
    73058_Porting_a_ResNet-50_CNN_application_to_a_ZedBoard_2019_2
    But I haven't installed vivado 2019.2 any time. But I installed vitis 2020.2. So here I tried to make this example but vivado 2020.2 gave error because of thedifferent version.
    I write this in xilinx forum but they said that zedboard team can help you.
    So I wrote this problem here.
  • drozwood90
    0 drozwood90 over 5 years ago in reply to muhammetalia
    Hi there,
    That is only mostly true.  We support ZedBoard with everything that is on the E14 product page.
    ZedBoard
    You would need to head to Digilent's support forums for anything newer.
    https://forum.digilentinc.com/
    I am thinking this sub area:
    https://forum.digilentinc.com/forum/4-fpga/
    Aside from that, if that document was written by Xilinx, they are supporting it.  I am sorry that we do not work with ZedBoard beyond what is on the product page.  Digilent has a very active ZedBoard community and if Digilent cannot help you, it is quite possible another user can.
    --Dan
