Avnet Boards General BD 41-237 Bus Interface Property FREQ_HZ does not match
  • Subscribers 372 subscribers
  • Views 1783 views
ssh24
ssh24 over 7 years ago
I am using a Tri Mode Ethernet MAC along with a AXI direct memory access in my design.
When I have my design ready I run Synthesis which fails due to the errors listed below:
           [BD 41-237] Bus Interface property FREQ_HZ does not match between /tri_mode_ethernet_mac_0/s_axis_tx(125000000) and /axi_dma_0/M_AXIS_MM2S(100000000)
           [BD 41-237] Bus Interface property CLK_DOMAIN does not match between /tri_mode_ethernet_mac_0/s_axis_tx(/clk_wiz_clk_out1) and /axi_dma_0/M_AXIS_MM2S(design_1_processing_system7_0_0_FCLK_CLK0
I tried changing the properties but its read only. Also the result is not reflected after changing the xml and xci files.
Awaiting your suggestions
Thank you
Regards
ssh24
