Avnet Boards General Linux on Zedboard
  • Subscribers 373 subscribers
  • Views 725 views
  • zync 7000
  • linux debian
  • ad9361
Linux on Zedboard
weberflo
weberflo over 7 years ago
I've got a problem with a ZedBoard Zync7000.
We are using two of them with a Analog ad fmcomm3.
I used for both identical boards the same SD Card (with the same configuration of the Linux System).
One Board is booting normally and works like id should, the other puts the Power LED light on, but the Done-LED doesn't light on.
The Board also does not communicate with the UART interface.
Can everyone help me, and know, why the board do not boot up?
Best regards
Florian
  • jafoste4
    jafoste4 over 7 years ago
    Hi Florian,
    Please verify the jumpers on the board that is not working are set the same as the working board.
    -Josh
  • weberflo
    weberflo over 7 years ago in reply to jafoste4
    Hello Josh,
    Thanks for your response.
    The Jumpers are set on both boards in the same order.
    Do you have any other idea, what can went wrong?
    Best regards
  • jafoste4
    jafoste4 over 7 years ago in reply to weberflo
    Hi Florian,
    If you have 1 working board and a 2nd nonworking board that are both connected and configured the same way. You most likely have a damaged board.
    -Josh
