Avnet Boards General XAPP1079 in vivado 2018.3
  • Replies 13 replies
  • Subscribers 374 subscribers
  • Views 2164 views
vicfer89
vicfer89 over 7 years ago
I'm trying to use XAPP1079 to Vivado 2018.3.
It works properly when the compiled code is lanched in debug, but if it is loaded into flash memory it does not work.
Have somebody faced this issue?
Thanks in advance.
  • jafoste4
    jafoste4 over 7 years ago
    What hardware are you using?
    -Josh
  • vicfer89
    vicfer89 over 7 years ago in reply to jafoste4
    Hi Joshua,
    I've tried flashing both Zedboard and Enclustra Mars ZX3.
    Thanks un advance,
    Kindest regards.
  • jafoste4
    jafoste4 over 7 years ago in reply to vicfer89
    Does it work when booting from SD Card?
    -Josh
  • vicfer89
    Hi Josh,
    Same bahavior as for QSPI...
    Thanks for the support
    -Víctor
  • jafoste4
    Hi Victor, Can you share your .bif file when generating the Sd card image? Also just to confirm, are you changing the boot mode jumpers when trying to boot from QSPI or SD?
    -Josh
  • vicfer89
    Hi Josh,
    .bif is as follows:
    //arch = zynq; split = false; format = BIN
    the_ROM_image:
    [bootloader]C:\Test_Vivado\project_2_CPP\project_2_CPP.sdk\main_fsbl\Debug\main_fsbl.elf
    C:\Test_Vivado\project_2_CPP\project_2_CPP.sdk\design_1_wrapper_hw_platform_0\design_1_wrapper.bit
    C:\Test_Vivado\project_2_CPP\project_2_CPP.sdk\main_ARM0\Debug\main_ARM0.elf
    C:\Test_Vivado\project_2_CPP\project_2_CPP.sdk\main_CPU1\Debug\main_CPU1.elf
    Thanks in advance.
  • jafoste4
    Hi Vic,
    It looks like your generating everything correctly.
    Following the order of FSBL - Bitstream - Application.
    Are you sure your jumper position is correct?
    -Josh
  • vicfer89
    Hi Josh,
    I'm researching in that guideline... I think that the issue is caussed by BSP or FSBL generation. Is it possible that Vivado/SDK 2018 does not incorporate AMP capability as well?
    Thanks for all your support.
    Regards.
  • jafoste4
    Did you specify to include the AMP in the BSP? Typically when generating a FSBL, you let SDK create its own BSP, you would then need to go back in and modify it for the AMP capabilities if i am remembering correctly.
    -Josh
  • vicfer89
    Hi Jeff,
    I did it. At BSP for ARM-01 I set the flag -DUSE_AMP = 1. But i didn't perform any change at FSBL, and as you said, i let SDK creating its own BSP for FSBL. Do you have some guidelines about what have to be changed at both BSP and FSBL? and, of course... would you be so kind as to share them with me?
    Thanks in advance and for all your support.
    Victor.
