K24 Development Kit Reference design
  • +1 person also asked this people also asked this
  • Subscribers 277 subscribers
  • Views 1120 views
Reference design
eeskbala
eeskbala over 1 year ago
We have managed to download the WIC file from the Avnet product page
https://www.avnet.com/wps/portal/us/products/avnet-boards/avnet-board-families/k24-development-kit
However, could you please let us know where to find the relevant design files (Vivado, Vitis/BSP) we can use to generate the image ourselves?
We found the board definition files here, https://github.com/Avnet/bdf
Also, useful will be the version of Vivado used for building this reference design? 2023.2 or 2024.1 or something else?
Regards
  • glenncb
    glenncb 10 months ago in reply to glenncb +2
    BTW - I found the answer but it wasn't super obvious to me so I thought I would share. I didn't realize the BSP file is actually a compressed tar archive which contains everything including the complete…
  • lightcollector
    lightcollector over 1 year ago in reply to glenncb +1 verified
    Hi, The specific repo is https://www.github.com/Avnet/hdl . This contains tcl scripts that put together a Vivado project for all of the Avnet/Tria boards. Avnet/Tria does not have a repo with direct Vivado…
  • iksevas
    0 iksevas over 1 year ago
    All of the files used to generate the BSP are in the https://github.com/Avnet repositories.
  • iksevas
    0 iksevas over 1 year ago in reply to iksevas
    Also, the K24 is fairly new so it is only supported in 2023.2, 2024.1 and 2024.2 branches.
  • glenncb
    0 glenncb over 1 year ago
    I'm specifically looking for the vivado project (xpr) file, block design, etc.  All I have been able to find are the board definition, constraints, etc.  Can anyone point me to the area which has the actual Vivado project files?
  • lightcollector
    +1 lightcollector over 1 year ago in reply to glenncb
    Hi, The specific repo is https://www.github.com/Avnet/hdl. This contains tcl scripts that put together a Vivado project for all of the Avnet/Tria boards.  Avnet/Tria does not have a repo with direct Vivado project xpr files for the board you asked about.  Please make sure you select the correct github version branch for the tools version you are using.
  • glenncb
    0 glenncb 10 months ago in reply to glenncb
    BTW - I found the answer but it wasn't super obvious to me so I thought I would share.  I didn't realize the BSP file is actually a compressed tar archive which contains everything including the complete Vivado project, block diagram, XPR file, Petalinux image files, etc.  Just download the BSP file and extract it.  You can rename the bsp extension to ".tar.xz" (as it is a tarred XZ compressed image) and you should be able to extract it under either Windows or Linux.  Iksevas is correct above - just download the BSP from the github/Avnet repo.
