K24 Development Kit Ps error out
  • Subscribers 277 subscribers
  • Views 778 views
Ps error out
sam_jones
sam_jones over 1 year ago
i received a K24 board today and started started a bring up.
Unfortunately PS Error Out turns on once i power on the board. This occurs regardless of the boot source (i.e. SD card / QSPI).
I understand that PS Error out could be most probably triggered by the PMU. Is there a way to read the PMU error signals ?
Has anyone encountered a similar scenario ?
Thanks & regards
  • iksevas
    iksevas over 1 year ago +1
    You should be able to read the registers via JTAG and hardware manager tool. You can find JTAG status registers and Error status registers there. With MPSoC, the error led is usually an incorrect boot…
  • iksevas
    0 iksevas over 1 year ago
    With MPSoC, the error led is usually an incorrect boot mode setting or something with power.
  • sam_jones
    0 sam_jones over 1 year ago
    If anyone is facing a similar issue , i would recommend that you have a look at your sd card. Otherwise check boot partitioning on sdcard before using balena etcher.
  • iksevas
    0 iksevas over 1 year ago in reply to sam_jones
    What SD card did you end up using? I feel like the MPSoCs want something on the smaller side and to SDHC in the class 10 range for robustness. I do know that SDXC is has been a no-no.
