MaaXBoard Hardware Design Missing module files 4.14.78 (linux-headers-4.14.78)
  • Subscribers 358 subscribers
  • Views 2144 views
  • debian
  • linux-headers-4.14.78
  • kernel module
  • maaxboard
  • linux
zafersen
zafersen over 4 years ago
Hi Everyone,
I am working on developing a kernel module. SO To compile,  I need to install the headers for the exact version of my kernel build(4.14.78).  I checked /lib/modules/ and there is a file named 4.14.78 in it. However, the build file in it is empty (broken symbolic link). Then I tried to install Linux-header that is the same version as my kernel build version. But I got some errors like below. I haven't found any solutions yet. Do you have any solutions or ideas?
root@maaxboard:/lib/modules/4.14.78# apt-get install linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package linux-headers-4.14.78
E: Couldn't find any package by glob 'linux-headers-4.14.78'
E: Couldn't find any package by regex 'linux-headers-4.14.78'
root@maaxboard:/lib/modules/4.14.78# ls -l
total 356
lrwxrwxrwx 1 user user    26 Jan 14  2020 build -> /home/embest/compile/linux
drwxrwxr-x 9 user user  4096 Jan 14  2020 kernel
-rw-r--r-- 1 user user 63521 Jan 14  2020 modules.alias
-rw-r--r-- 1 user user 68154 Jan 14  2020 modules.alias.bin
-rw-rw-r-- 1 user user 31857 Jan 14  2020 modules.builtin
-rw-r--r-- 1 user user 34659 Jan 14  2020 modules.builtin.bin
-rw-r--r-- 1 user user 22212 Jan 14  2020 modules.dep
-rw-r--r-- 1 user user 35969 Jan 14  2020 modules.dep.bin
-rw-r--r-- 1 user user    98 Jan 14  2020 modules.devname
-rw-rw-r-- 1 user user 12832 Jan 14  2020 modules.order
-rw-r--r-- 1 user user    85 Jan 14  2020 modules.softdep
-rw-r--r-- 1 user user 29705 Jan 14  2020 modules.symbols
-rw-r--r-- 1 user user 36180 Jan 14  2020 modules.symbols.bin
lrwxrwxrwx 1 user user    26 Jan 14  2020 source -> /home/embest/compile/linux
root@maaxboard:/lib/modules/4.14.78# cd /home/embest/compile/linux
-bash: cd: /home/embest/compile/linux: No such file or directory
-bash: cd: /home/embest/compile/: No such file or directory
-bash: cd: /home/embest: No such file or directory
  • jwlembedded
    jwlembedded over 4 years ago in reply to zafersen +1
    Good to know that you still giving it some effort. I will look into this asap. Do you mind sharing some info with regards to the distro you were initially working with? Also I just wanted to make sure…
  • jwlembedded
    0 jwlembedded over 4 years ago
    Hi Zafersen,
    Did you manage to cross this bridge? If not we are now monitoring the forums and are here to help.
    Jason
  • zafersen
    0 zafersen over 4 years ago in reply to jwlembedded
    Hi jwlembedded, unfortunately, I haven't done it yet, as far as I remember to fix this problem I needed to reach 01LinuxSourceCode folder but its link was broken. now Im working on Yocto project on maaxboard.  if it is reachable, please let me know.  But of course, if you release a new image file that fixed the problem which I mentioned above, it would be great.
    Thank you
  • jwlembedded
    0 jwlembedded over 4 years ago in reply to zafersen
    Also I just wanted to make sure you were aware of the Maaxboard yocto layer we have created. Its housed on the Avnet Github https://github.com/Avnet/linux-imx. If you build using the provided yocto layer are you still not seeing the required header files?
    Cheers!
    -Jason
  • zafersen
    I got this error above when I was working on Debian Linux Out of Box Image (zip) which is linux debian 4.14.78 kernel version.  I would prefer to work on linux debian distribution. Unfortunately, I struggled with many problems on that. So I moved all my work to yocto. There is no problem so far with maaxboard yocto layer. But  I am using maaxboard yocto instruction and yocto layer in this link https://github.com/Avnet/meta-maaxboard. Are you sure that link belongs to maaxboard yocto layer?
    In addition, the same problem under the Compiling modules/drivers for kernel 4.14.78 title was also mentioned here /products/devtools/single-board-computers/f/forum/10638/maaxboard-debian-image---tips-add-ins-and-fixes , they shared some links in that discussion to fix the problem but they are all broken links.
  • zafersen
    Have you had time to check this problem out: https://github.com/Avnet/maaxboard-debian-build/issues/1. I think it might help me to understand debian distribution.
